Not sure if anyone has run into this problem as most phone calls are met with voice mail or an answer but every time I make a call and it is met with a busy signal it won't go away even after i hang up. The phone is hung up and I can go to the home screen and use other applications and the busy signal is still buzzing through the speaker. The only way I have been able to end the busy signal is to restart the phone or shut it off.
Any ideas or suggestions to remedy this?
