Root stuck in bootloop after flashing gingerbread
skytbest
I tried flashing the zip file posted here
How to: Get Rooted Gingerbread on DROID 2 - Droid Life: A Droid Community Blog
I now realize that I forgot to wipe my cache and clear data before I did. My phone is stuck in a bootloop now and I cant lap recovery, is this because bootstrap was removed when I flashed the update? What can I do, can I even SBF at this point?
Also when I try to boot into the droid recovery by holding x and the power button and then the search key, nothing happens when I hit the search key (yes im hitting the hardware button, not the touch one)
Thanks
The new gingerbread build has a different method of accessing the recovery menu. After starting with the Power + X key, then you have to press the two volumes keys at the same time (similar to pressing the search key previously). This should get you to the bootloader menu. To use the menu - that has changed too: Power button is select this time. Use volume keys or keypad arrows to navigate the menu.
That should help. Never-the-less, for whatever reason that fails, you can still SBF back to 2.3.20 stock, and then re-root from there, bootstrap, install update, and so forth. ;)
