stuck in bootloop
kiran8589
hi
i have moto e4plus(xt1770) rooted one week back, i received an update and after i installed it it was going to twrp again and again then i downloaded stock rom and flashed stock recovery now it is stuck in bootloop please help........
hi
Use fastboot instead of TWRP to install the proper MediaTek (nicklaus) FirmWare and you should be fine. Yes, look for 'nicklaus', not 'owens' or you'll be bricked.
Make sure you install the exact same FW )compare file names to your Settings - About Phone to find your match) that your device came with or you'll have serious issues.
Also for future reference, never try to use TWRP to update stock firmware.. All our files here in Android Forums is for the 'owens' (Qualcomm) version, not 'nicklaus' (MediaTek).. The files you need will be in XDA.. FYI
Edit: NVM, I got the link for ya. Here's what Motorola Has posted on their website for nicklaus - https://firmware.center/firmware/Mo..._3_subsidy_UNLOCKED_model_LATAMDS_CFC.xml.zip
