C
Chris Alloway
Guest
I used ROM Manager and flashed CWM Recovery 5.0.2.7 to my Vortex running 2.2.1....now I am stuck in recovery after attempting to flash CM7, but the Home button (or any other button) will not work to select the highlighted option. I am doing research to see if I can find some kind of option to fix my mess up but it is not looking good. I had to take out the battery, hold volume up and power and home while i plugged in the charger just to get into recovery because i was stuck on the splash screen. If anyone can provide assistance on this I would be very appreciative. The carrier is VZW. Is there a way I can push the correct recovery through ADB?
