Root Stuck in Rooting Process
hmarcus
I went ahead and attempted to root my Rogers Magic, but at the point where I'm in fastboot mode and cmd prompting "fastboot boot recovery.img" it says "waiting for device" instead of "downloading". Any thoughts about what that means?
PS
The update.zip is on my sd card and the recovery image is in my tools directory.
Thanks in advance.
i figured it out.
Install the drivers for your device.
Its in the SDK. Just manually install them Control Panel>Device Manager>Then select the usb drive the phine is in>right click> properties>select the drivers tab and update it using your software from the sdk which is located under usb_driver\amd64.
hope that helps.
