Root Stuck on manual screen
I have a Samsung Galaxy Apolo i5800 and I can't get it off of the manual screen.
To get it on the manual screen, I pressed the home button/volume button/power button.
Now it says:
Android system recovery
Samsung recovery Utils
- for BML -
and the options are:
reboot system now
apply sdcard:update.zip
wipe data/factory reset
wipe cache partition
and at the bottom of the screen it says:
# MANUAL MODE #
multicsc: src /system/csc/TMU/system/ .
I put it on manual mode so i could wipe the data, but now I can't get it off of the manual mode, because when I reboot the system, it just goes back to Manual mode.
Please help me!!
Thank you
Hi
When in "manual" mode as you call it, scroll down to the reboot system now option using the volume buttons. When its highlighted press the power button.
Is that what you have tried?
Roger
