Droidbunny
Hey, New to the Droid Family and i think i have a serious problem but really hoping its not! I Have here a "T-mobile mytouch 4g slide"(htc) that only boots up to the white screen with the writing (.T..Mobile MyTouch 4g slide) and permanently stays there until the battery is dead or pulled! The card slot works fine, volume keys as well... I tried to factory reset and recovery from hboot screen to no avail....
Can Someone Please Direct me to a FIX or tell me what i can do... I'd really appreciate it!
Thanks!
Thanks!
Thank You!
