23Six Lurker Nov 6, 2012 #1 I'm using Temp+CPU PRO which provides accurate battery temp (20-30C) I guess the question is, is this accurate/normal? Screenshots for celcius: Farenheit: BQ: Update interval for the widget is 1second.. notable battery hog?
R rcsrich Android Expert Nov 6, 2012 #2 Gonna have to go with a no on that one! Sadly, I have no idea why it would not be reporting the CPU temp properly...
G GoldenDiamond Well-Known Member Nov 6, 2012 #3 woot, go big bang theory! love that show! but staying on topic, I think there is something going on with that app. don't think you have liquid cooling in your phone either. I would try minimalistic text and see what it says. https://play.google.com/store/apps/...1bGwsMSwxLDMsImRlLmRldm1pbC5taW5pbWFsdGV4dCJd EDIT: BTW, what skin/rom are you using?
