[SUGGESTION] Please keep the audio fix toggle in Virtuous Buddy
Status
Not open for further replies.
anicotra
Member
rmk,
Please don't remove the audio fix option in Buddy. I've done some bench marking between streaming audio with and without the fix.
Streaming with http=false draws half the current as streaming with it =true. I'm seeing 60-70ma when false and 120-140ma when true, with no noticeable difference in quality, at least on slacker.
I'm sure quality is important to most people, to me as well, but so is battery draw. That's why I would like the option to remain.
Thanks for your continued support. I think you have the most stable Rom, with the most user selectable options. Keep up the GREAT work.
No problem, we'll keep the option around then. I'll probably rename it to reflect what it actually is, toggling stagefright http on/off.
Agreed.
One more thing. Is there a way to make the toggle selection persistent between reboots? I think I remember you saying you enable "http=true" via your scripts at boot time.
Agreed.
Yep, I'll make the toggle persist between reboots as well.
Status
