Suitable screen protector for thin case
slippyjim
Hi,
So I smashed the screen on my S7 so decided I should get a screen protector to hold it together a bit until I can replace, yes I know I should have done this awhile ago....
20190313_171556-1-jpg.140426
I have a thin silicone type case for it that overlaps the top edge 1-2mm but I can still see part of the white bezel down each side, I've been looking at many different brands and the width seem to vary greatly, any advice on one that will fit mine best?
Thanks
Just so you know some screen protectors can be cut to size. They come in an oversize sheet and you cut them down to the size that will fit your smartphone.
