sun pak selfie wand
lily v
y guys so I just bought a new selfie wand it's called "sunpak ". Its says all androids can use it but they may experience the camera zoom when shutter release button is pressed & if it occurs to change the settings on the camera & change the volume key to camera key. But my phone doesn't have that option. Help.
Hello!
So you need your device to silence the shutter sound when using said selfie stick?
I don't know how a selfie stick works but what device do you have?
Also, what android version and what camera app do you use?
Furthermore, just because it says "you may experience..." doesn't mean you "will" experience it. Are you using it now? Does it work as expected? I have reviewed a selfie stick before, and they are all basically the same where you have to link it to your phone through bluetooth. The shutter button usually linked by default to take pictures, so it should work right out of the box with all the latest phones and default camera app. But nothing is 100% guaranteed.
So before you try to change or troubleshoot anything, can you please confirm if you are having a problem or just worrying that you might have a problem? ;)
