over the past 2 months of owning this phone, i still love it and all its features. but the one major issue that has drove me insane was the battery life.
note: i have tried everything from "battery savers", clearing ram, using apps to find what is draining the battery (helpful to an extent but did not exactly say what app was causing the drain), battery saver options, low screen, killing mobile data.
enough was enough. i shouldn't have to jump through hoops to get ideal battery life when others are getting it right of the box. i don't go and download goofy apps either that would cause this. i don't have LTE yet, but its predicted to be running by next year.
my battery would run hot and drain within 12 hours (with less than 10% being screen time) android system would be the culprit.
i finally called AT&T, they are shipping me a new unit, should get here by friday. I will run the phone completey stock on a full charge and record the battery life, then install my usual apps and launcher and record those.
hopefully i get a longer lasting device. to those who are fed up and have tried everything. consider a replacement. mine was over the 30 day warranty and no insurance, but call AT&T directly and they will take care of you, as for other providers, no clue.
stay tuned.
stay tuned.
