Help Swiftkey deletes words when two handed texting
I am coming from an Incredible and a Rezound and Swiftkey worked perfectly on these, but on the Razr, if I type with two hands, it's almost like the phone cant keep up. It erases entire words, or two letters at a time, but I can almost never complete a sentence if I am typing with two hands. I have it set on Precise and have tried Rapid with no improvement. Any ideas why this is happening or how I can correct it? I dont want to have to use Swype if I dont have to. Thank you!:o
You can delete entire words by swiping right to left on swiftkey, so it sounds like you're triggering that by accident. I know I've had that bug in the past.
You can disable that in the settings, or increase the required swipe distance to tone it down.
Even disabled, this doesn't help. It keeps deleting every other letter when I type with two hands and is really inaccurate with the selections and letters I press with the left hand.
I had the exact same problem when I first bought my RAZR. All I did to fix it was disable the gestures like stated above. If still not working did you set it up for precise or rapid texting? Just an idea.
