Help Switch between WiFi and Data
amorley77
Hi all! Just got my Note 8 last Friday and still figuring it out. Love this phone!!
So I am wondering if there is anyway to set it when my WiFi signal becomes weak it automatically switches to Data?
For example when I am out in my garage (detached) I have a weaker signal so everything loads extremely slow and it won't use LTE to compensate. I have to manually turn off WiFi.
It's not a huge deal but it would be a lot more convenient for when my hands are all dirty and the streaming music starts to lag.
Any and all input would be appreciated
It switches automatically anyway, there is an aggressive setting in the WiFi menu which is supposed to switch between the two more.. Aggressively.
Turn adaptive on
I've turned it on, but there are no other options besides on/off.
Select Adaptive WiFi and another menu will open with more options
I tried again, but the only options I have are on or off.
Nope, there is no other field on my phone.
I have the Exynos (International) chip version, don't know if there are regional differences here.
You may need developer options, search for aggressive in your apps drawer search bar, if it's not there, you need developer options activated.
What’s your carrier Teris?
Ive a T-Mobile variant and its there in the standard wifi settings.
If you’re on ATT or VZW they may have that shut off.
I have the locked Carrier (Sprint) version. So weird that the same option is in a different place depending on the phone.
And mine is under the Advanced WiFi settings
Now that I have had time to dig around on the device I have noticed something in developer mode. There are a couple of options that directly influence WiFi vs Mobile Data. I was just curious about this specific option.
Will turning this on constantly use mobile data?
Or is it more of a battery life issue?
it will only use data when wifi is not robust or weak.
anything that is running will consume SOME battery but it won't be cause for any alarm.
if you are having data connection issues then activate it. if all is working, then don't do anything.
