Hi guys
I'm relatively new to Android on a BHII running Behold 2 1.6 ( No Twiz w/ Busybox & Rooted Kernel ) which I flashed using ODIN.
I'm now wanting to try Galaxy 1.6 as well as Factory 1.6 for comparison before settling on the best ROM for my needs.
Is it currently preferable to use Rom Manager Premium to backup my existing setup, then use it to flash to Galaxy, etc. or can I only switch roms on the BHII using ODIN? The Galaxy install, with fixes for example, looks beyond the scope of Rom Manager.
Effectively, I'm wanting to recover or restore the desired ROM as simply as possible, without the need to reinstall apps, reconfigure settings, etc.
Thanks for any direction!
