Hi,
I have a simple question for those of you who already own the phone (I am thinking about buying the Virgin Mobile LG Volt). When you switch the phone from "LTE" to "CDMA" under system settings, does the phone require you to reboot? Or does it simply switch to "3G" without having to restart the phone? (of course it may take 5 seconds or so to change)
The LG F3 did not need a reboot when you toggled between CDMA and LTE, and I was wondering if this phone allows you to do the same.
Any help would be appreciated.
Thanks!
Thanks!
