hackebacke
I have a Samsung S3, an iphone, a Volvo, and a Bose Bluetooh headset.
When using the Iphone, it could be simultaneously connected to the car and the headset. If a answer with the car, and having people in the car and want to have a private conversation I could easily press on the Iphone screen, choose output-device and change from MyVolvo to Bose BT and after a second the call is transferred to the headset. Same routine to reverse if I want.
When using my Samsung S3 (which I prefer) I can only have one bluetoth device connected for phone purposes. To change output I need to disconnect the car, and connect the headset. It takes a loong time.
Does anyone know if there is any way to come around the problem? Or if it about to be solved in coming versions of Android.
Got a similar problem regarding outputproblem today. Was listening to music via headphones (3.5 mm), when entering the car, my phone connected to the car and suddenly the output was changed to bluetooth. I did though not find any option to change audio output back to my headphone unless turning the bluetooth off (or disconnecting the device).
