swype keyboaed
  • Start date Start date
A
Android Question
Guest
I have samsung galaxy grand, android-4.1.2 . i downloaded swype keyboard and selected it for use. After that
i locked my screen and tired to type my password. BUT keyboard was not opening. Now i can't use my phone.
Have you tried resetting your device to see if the keyboard is just frozen? If that doesn't work, then you might have to perform a factory reset from within recovery to remove swype keyboard. To do this, first power off the device. Once that device is off, hold volume up + home, then add holding power until the device attempts to boot. Once recovery mode boots up, use the volume keys to navigate to wipe data/factory reset. User the power key to confirm.
