swype with 2.1 on droid
MarcMaiden
Hey guys,
quick question,
Im ready to try out swipe, but i am not sure if it works well with the new 2.1 update, so before i go downloading it, anyone have any problems with swype and Droid 2.1?
thanks!
in saying that, if you download sywpe off the internet and upload it to your phone, you have to uncheck that you allow this app to be downloaded, becausing this app isnt comming from the market does it void your warranty?
i had swype, but now it says that it is expired. can i un install it, then re install it and will it work again? someone said it was a limited beta, but if others are still using it, there must be a way to have it re enabled. can you let me know how to do this? thanks.
I have it downloaded, but the app doesn't show up on my app list, but it does on the "manage app" list where you uninstall apps.
How do I get this to work?
I have the OTA 2.1 update and am using Swype with no issues (other than the input switching that's been an issue for awhile).
You have to uninstall both Swype and the Swype installer.
I then went to the Swype site, re downloaded the installer then the program. The same steps you took when you first installed.
I dont see anything on the website that has any downloaders. Am I on the right site?
Swype | Text Input for Screens
No. Installing third-party apps that aren't from the market (whether they're from websites, your SD card, your cat's hairball) doesn't void your warranty.
it is a great app, i downloaded it but I uninstalled it because it only works in the English language. I am bilingual and I also text in my native language and I have to tap every letter to to enter a word Hopefully when the final version comes out, it will work in some other languages too
i had the original leaked version of swype, it ended, noiw i can't get it to work, nor the 5612 version. The keyboard comes up, but it doesn't "swype"
Anyway i can get it working until we have an official version available?
