Sync Not Working Well
persistentone
For one of my Google accounts, sync to the cloud has stopped working reliably. This is affecting both a Samsung Galaxy S4 phone as well as an original Samsung Note 10.1 2014.
Here is what transpired on the phone:
1) Today I noticed that a contact of a family member disappeared on the phone. That contact still exists on the cloud version of Contacts. I re synced the Contacts app and this did not fix anything.
If I delete a contact on the phone, shouldn't that delete on the web if everything is working?
2) I exported the contact on the web, then renamed the original contact to a backup name. I then imported the saved contact and created a new contact and gave it a unique name that reflects that it was a restore. I go to the phone and the contact does NOT appear on the phone. I forced a resync and this did not fix anything.
3) I went to my tablet and the contact existed both on the tablet and the cloud. I renamed the contact on the cloud and it shows renamed on the tablet. But the new contact I create on the cloud never appears on the tablet, even after I force a resync of contacts.
It looks like sync for this account is broken.
I already contacted Google support and Samsung support, through Verizon. Their recommendation is to remove the account from the phone and add it back. I want to make sure I understand the implications of doing that.
Will this delete all of my contacts locally on the phone? If for some reason sync is really broken for this account, then if I add the account back my phone would basically become useless since information would not populate from the cloud to the phone.
I find it almost impossible to navigate the forum topics on this website and to understand how to just post simple Android questions. Is there some basic Android Support forum that is not tied to all this specific detail about the type of device? I think my question is really about Google applications and the general function of sync, not specific to Samsung model numbers.
You might want to ask about your sync problem here. It's an area for general Android questions. Good luck.
