sys android emulator is not working
how can i resolve this issue
  • yes
    Votes: 0 0.0%
  • no
    Votes: 0 0.0%
  • Total voters
    0
12-02-2019
06:39 Gradle sync started
06:44 Project setup started
06:45 Gradle sync finished in 5 m 15 s 597 ms
06:45 Syncing only active variant
You can disable this experimental feature from
File → Settings → Experimental → Gradle → Only sync the active variant
06:45 Executing tasks: [:app:generateDebugSources]
06:45 Gradle build finished in 6 s 705 ms
06:53 * daemon not running; starting now at tcp:5037
06:53 * daemon started successfully
06:53 Executing tasks: [:app:assembleDebug]
06:53 Emulator: C:\Users\Rishal Babu\AppData\Local\Android\Sdk\emulator\qemu\windows-x86_64\qemu-system-x86_64.exe: WHPX: Failed to create partition, hr=80070005
06:53 Emulator: C:\Users\Rishal Babu\AppData\Local\Android\Sdk\emulator\qemu\windows-x86_64\qemu-system-x86_64.exe: failed to initialize WHPX: Invalid argument
06:53 Emulator: Process finished with exit code 0
06:55 Gradle build finished in 1 m 39 s 841 ms
