newdaddy2014
When I want to screen shot on my phone it says 'unfortunately system AU has stopped working' how do I fix this?
How do I do this? And would it remove anything of my phone like my pics and vids as there of my 2 kids?Try to reboot the device and try it again![]()
Oh, sorry, by "reboot", I mean power the device off, then back on again. This will clear any wonkyness such as the UI errorHow do I do this? And would it remove anything of my phone like my pics and vids as there of my 2 kids?
So click on 'power off' then turn the phone back on? Or click on restart?Oh, sorry, by 'reboot', I mean power the device off, then back on again. This will clear any wonkyness such as the UI error![]()
Correct. Restart is fine, same thing.So click on 'power off' then turn the phone back on? Or click on restart?
Well, at first I thought the "AU" was a typo. Does it really say, "AU"? or "System UI"?I have done this in the past since the AU thing happened and it still comes up, is there anything I could do via the settings?
Unfortunately system UI has stopped working, typo sorryWell, at first I thought the 'AU' was a typo. Does it really say, 'AU'? or 'System UI'?
Unfortunately system UI has stopped working sorry it was a typo my bad hahaWell, at first I thought the 'AU' was a typo. Does it really say, 'AU'? or 'System UI'?
Ah, ok. So powering your device off, then on does not help your error when trying to take a screen shot eh?Unfortunately system UI has stopped working, typo sorry
That makes sense because I was playing on the phone it updated the phone with the android bot then that's when the thing stopped working.Ah, ok. So powering your device off, then on does not help your error when trying to take a screen shot eh?![]()
Hmmm, has the device had an update of some sort lately?
Understandable. Sometimes updates cause some unintended errors such as yours.That makes sense because I was playing on the phone it updated the phone with the android bot then that's when the thing stopped working.
Google says hold all the buttons down and it will clear the cache . I don't want to wipe the phone as I have pics and vids ect.
So I just need to click on the link and follow the instructions? I really can't loose anything on the phoneAh, found it:
http://www.hardreset.info/devices/samsung/samsung-a300f-galaxy-a3/recovery-mode/
Just be sure to clear the cache only....not factory reset. Once you clear the cache, you can choose to reboot. You will not lose anything.
That is correct. Just remember to wipe the cache partition only. Once done, highlight the reboot option and you will be back up and running...nothing is lost.So I just need to click on the link and follow the instructions? I really can't loose anything on the phone
I have done everything that the link says ant it was stuck on the Samsung screen for a while. The phone wouldn't turn on, somehow I managed to get it back on it didn't work...That is correct. Just remember to wipe the cache partition only. Once done, highlight the reboot option and you will be back up and running...nothing is lost.
sorry for the late reply...it was getting late here and I had to get some shuteyeI have done everything that the link says ant it was stuck on the Samsung screen for a while. The phone wouldn't turn on, somehow I managed to get it back on it didn't work...
