Help System cleaner
tarquin
What app would you recommend to clean your system?
Have used Clean Master and CCleaner, but I feel these just slow my system down.
Any recommendations.
My tablet is shop bought, no fancy rooting etc.
Thanks all.
Welcome to Android forums!
What tablet do you have? What android version?
Don't use any of those cleaning apps. Clean Master is from Cheetah Mobile and they are evil. And, yes, Clean Master will slow your device down. It is snake oil.
CCleaner is unnecessary. You can use the built in cache cleaner in Android.
If you really want 3rd party app use SD maid to clean the cache.
