Help "System encounter error will exit later"
bkleinkn
I have a Galaxy S6 Edge that has this message flashing on the bottom of the screen all the time. Restarting the handset doesn't fix the issue. It started today and I don't recall doing anything unusual to the phone. I haven't modded or tinkered with the phone at all, it's the same way it was when I bought it new from Verizon.
Anyone know what is up?
I was having the same problem, so I decided to start turning things off one by one. I eventually turned off an app called ZingBox which is a Manga reading app and it fixed the problem.
Hi! I'm not the person who posted this question, but searching my problem on internet I found your answer and I just want to say thank you so much, I had that freakin error message popping for three days now and I could not find anything because i was searching for the message in spanish and I almost reset my cellphone! I uninstalled Zingbox and problem solved, so, thank you, thank you, thank you!!!
