I own an LG G6. I used to be very happy of it, till a recent update, on Dec. 20, 2018. The current SW version is at the end of this message.
After this update, the "LG System Server" utility frequently switches on with the following warning: "Check USB port. Moisture has been detected [...]" although the telephone has NOT been exposed to moisture. The warning can switch on anytime of the day or the night, and is really annoying. Besides, it prevents charging.
I tried the following:
- to disable the "LG System Server" utility, but I didn't manage to in an obvious way;
- to press Volume Down + Power Button, i.e. to restart the phone. The problem persists;
- to completely reset the phone. I noted that after the reset, the software version is the same as AFTER the update that is the source of the problem. And in fact, the problem persists.
Is there a way to disable the "LG System Server" utility?
In alternative, is there a way to install a software version older than the current one, that is the source of the problem?
Any other help is greatly appreciated.
PS:
Android version: 8.0.0
Kernel version: 3.18.71
Software version: V20g-EUR-XX
PS:
