T-Mobile $30 plan with LG G2
Hi, so I was thinking about getting the LG G2 and was wondering if it works with T-Mobile's $30 100min talk, 5GB of text and data plan. Does anyone have this plan with the LG G2? If know one has this does anyone happen to know if it'll work with the plan? Thanks everyone!
Do you know which model of the G2 that it is? If it is the T-Mobile version, it obviously should work fine. If it is the AT&T version, you will need to be in a refarmed area (typically, an area with LTE) to get 3G/HSPA+ speeds; additionally, it will need to be carrier unlocked.
And, of course, the phone cannot be reported lost or stolen (blacklisted).
Any unlocked or T-Mobile GSM phone, compatible with T-Mobile's network, will work on the $30 plan.
Duplicate topics merged. I think you will get your best answers here OP. Good luck.:)
It is much prefer to have a T-Mobile phone if you can. Those refarm and odd frequency here and there by T-Mobile might not make you happy with 4G and LTE.
