VinhCTrinh1984
Is it possible to flash a T-mobile Samsung S5 to work with Metro PCS? If so what are the PROS and CONS if any. Thanks in advance
Step one: check the phones imie on swappa
Step two: if it comes back clear remove T-Mobile sim if it has it, if not skip this step.
Step three: put in metro PCs sim card.
Step four: dial *228 or metro full number.
Step five: Follow the metro rep's instructions.
On the gsm network flashing phones isn't a thing. The metro s5 and T-Mobile s5 are the same phones with sightly different apps. The only thing I think might give you issues may be the apns. But they are in the thread stickied at the start of the forum dedicated to byod. Anymore questions could be answered there.
Why?Op will need to remove the T-Mobile apps from the system .
