Craig Wheater
Hi, I have a t8 pro Android TV box and up until deleting kodi off it to try and update it my remotes worked perfectly fine. Now I can only use certain buttons and the rest seems to be locked out (or so it seems) I find it hard to believe that both remotes would be like this. I have tried to pair the remotes again and this hasn't worked. Because I can't use them properly I can't even update my kodi. I have set everything back to factory settings so perhaps this is why, is there anything in the settings which needs to be set again to allow me to use the remotes? Everything worked fine up until I reset back to factory settings and now the remotes don't work properly...anyone have any ideas or had the same problem?
