Wazzup_Dev
I am trying to add a Table Layout under a picture but it will not show up.
Code:
Code:
Code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_height="fill_parent" android:orientation="vertical" android:layout_width="wrap_content" android:layout_gravity="center">
<ScrollView android:id="@+id/scrollView1" android:layout_width="fill_parent" android:layout_height="wrap_content">
<LinearLayout android:layout_width="fill_parent" android:id="@+id/linearLayout1" android:layout_height="fill_parent">
<ImageView android:src="@drawable/item" android:layout_width="fill_parent" android:layout_gravity="center" android:layout_height="wrap_content" android:id="@+id/imageView1" android:scaleType="center"></ImageView>
<TableLayout android:stretchColumns="1" android:layout_width="fill_parent" android:layout_height="wrap_content" android:id="@+id/tableLayout1">
<TableRow>
<TextView
android:layout_column="1"
android:text="Test"
android:padding="3dip" />
<TextView
android:text="TEst"
android:gravity="right"
</TableRow>
</TableLayout>
</LinearLayout>
</ScrollView>
</LinearLayout>
