Tablet Batteries in bulk!
Might be able to find you a reputable wholesale supplier of Lipo tablet batteries in Shenzhen or HK. PM me. We'd very likely need to know the dimensions of the batteries your tablets need and the actual tablet model I think, and 500 should be doable.
Are all these tablets the same model and do they have user-replaceable batteries?
Some models are trivially easy to change the battery, but a lot of them are notoriously difficult, requiring intricate disassembly work plus lots of glues and adhesives.
Hi, thanks for the replies. I'm the Technical Operations Manager for the company, changing the batteries is very easy if one can operate a soldering iron!
I'll got the maximum dimensions later today.
Thanks guys
I tied to upload the images of the current battery battery, but they wouldn't show on the thread.
The spec is: 3.7V 7800MA 36140140 (3670140*2)
Dimentions are: 134mm x 128mm x 4mm (approx)
Hi, I can't see a message option, can you message me and I'll reply?
