tablet screen will not come on when the power is on
  • Start date Start date
A
Android Question
Guest
i have a android tablet, when i turn it on the screen will not come on, i have to bend it a little bit just to see it can you help.
Without knowing what kind of tablet you have or how old it is, it sounds like a definite hardware issue. If you just purchased it, I would try and exchange it for a new one. If it is under warranty, contact the manufacturer and see if they will do a warranty exchange.
Beyond that, we would need to know the manufacturer and model to see if there is a repair guide where you may be able to locate and fix what is likely a loose wire / connection.
