Tablet Skin not showing up in Studio’s ‘Create Virtual Device’
mdsousa
Hi
In trying to create an emulator of a Samsung tablet (Tab A 9.7 for example), I start with “New Hardware Profile” which goes to “Choose a device definition”
I’m not sure if it’s suppose to, but the Galaxy_Tab_A_9.7 does not show up, so I chose the Nexus 10.
As you can see, that is not a good selection (not big enough)
So if I go back to the “Choose a device definition” and click “Next”, on the next screen (Configure Hardware Profile small.png -- see attached) which is
“Select a system image” (attached image), there is nothing there to select from
Images referenced above are attached, I couldn't figure out how to insert them into the message flow.
I’m using Studio 4.0.
Any idea of what I’m doing wrong would be greatly appreciated.
Thanks…
