Help Task "persistent" is draining my battery. What is it?
halfbeing
According to Battery Mix, a task called "persistent" is using a fair amount of battery (~7%). What is "persistent"? Could it also be connected to the fact that my battery also seems to drain very quickly a lot of the time in a way that I can't pin down to particular apps? By this I mean that it often drains very quickly and the Android kernel and core are the main consumers according to Gsam.
