[Tasker] AutoInput usage
ldm1417
Member
Hi All,
Some apps has no an AutoStart option. As an example - WiFi FTP Server. After launcing the App, someone should touch (tap) the 'Start' button so that the server will start working.
Could touching the App be done using the AutoInput plugin for Tasker? How?
1-bmp.135949
Thank you!
Ok, I did this tutorial, Thank you! I also wrote a task which works, thank you again :-)
But, is there a command in Tasker, which waits for an app to be in a focus (the app becomes running in foreground, not in background, displayed on the screen)?
The only commands, which I found, are 'wait' and 'wait until', but it seems they cannot do this job ...
Thank you!
