chris_allen123
Hi everyone,
I have been getting on fine with Tasker, which I purchased direct after I found there was an option and I am attempting to create a repeating vibrate alert which repeats 3 times and then stops.
I have set the variable %COUNT to 0
Added the vibrate notification
I know I need to increase the value of %COUNT by 1 now as the walkthrough suggests, but in Tasker on my phone, I do not have a variable inc variable action to select in the Variables section, only clear, subtract, add, list, join, set, split and randomize.
I have tried the append with 'Do Maths" ticked in the hope that that would work, but all i can do is change the value of 1 to 11.
Does anyone have any suggestions?
Thanks,
Chris.
Thanks,
Chris.
