Tasker - How do I set an either / or context?
avensys
Hi,
I have Tasker load an app when it detects my car bluetooth AND my battery level is over 50%. This works fine.
However, I'd like it to load the app if the battery level is over 50% OR if power is connected instead but I just can't work it out.
Any help appreciated!
Kind regards,
Mark
Actally, that's a pretty good work around, thanks.
However, I now have two separate profiles. Each adds one to a variable (called %batpower) when it activates and deducts one on an exit task. One checks that the battery level is over 50% and the other checks if on power.
I then have a third profile that checks for Bluetooth and if the variable %batpower is greater than zero and loads the app. Since the variable will be greather than zero if either battery is over 50% or if on power this works just as I wanted. Granted I have three profiles instead of two :(
Kind regards,
Mark
