Tasker math expression does not evaluate
Hi,
I use an expression
if (%TIMES-%Offtime)
Endif
%TIMES = builtin variable of current time (e.g. 1560123456)
%Offtime = a variable set by me which contains an earlier time e.g. 1560000000.
which does not work, it appears that arithmetic expressions are not supported.
E.g when I log %TIMES-%Offtime then I see literally "1560123456-1560000000" instead of 123456 which is the numeric result.
Documentation of Tasker lacks anything about how to use arithmetic expressions.
How should I use them ?
arithmetic is definitely supported.
many actions (like variable set) have a checkbox labeled "do maths" which forces Tasker to mathematically evaluate the expression.
make sure that box is checked.
