takinatrip
Has anyone found a solution that works?
I can connect to my router but cannot transfer data as such am unable to browse or use any web based app etc.
I have full signal strength and all other devices connect and work fine: ps3 laptop netbook and other phones.
This is driving me nuts please help.
Info from HTC:
"HTC believe this is because you maybe using an N Type enabled router? HTC Android devices are not compatable with this type of wireless router. You will need to be using B/G enabled routers. You need MAC address filtering disabled or your device added to the exceptions if enabled. Your Routers instructions may help with the setup and settings."
Can anyone help me with MAC address filtering please?
Info from HTC:
