ForeverNewb
Member
This is by far the easiest remote access program I've ever used. Simply install the software on the host PC and your android device and your done. Connections are made with a unique 9 digit ID and random password or master password. The connection uses 256-bit AES encryption so you know your info is safe.
Oh ya and for non-commercial use all the software is 100% free.
If you sign up for a free account you can save partners(PC's you have already connected to) for future use. Also you can view the online status of partnered PC's.
This software is so easy to install a half brain dead monkey wouldn't have problems.
Mobile Download (Android/iPhone)
TeamViewer app for mobile devices (iPhone, iPod touch, iPad, Android)
note: Picture is from iPhone but Android app looks the same
