Snakeyeskm
Member
Hopefully, some of our technical gurus can help clarify my understanding of bloatware and its impact on storage/memory. (Calling EarlyMon, ironass, AZ).
As I understand it, bloatware installed by both Samsung and the carrier resides in a separate system partition in the phone storage. As such, when bloatware is disabled the user gets no additional storage capacity since the system partition is not accessible to unrooted phones. Disabling however, theoretically, reduces the amount of RAM utilized since the disabled bloatware no longer loads. However, given the efficient use and management of RAM by android, it is highly unlikely that this reduction will have any impact on performance. The bottom line being, disabling bloatware does little to nothing to help performance and storage capacity.
Assuming, I am summarizing correctly (unlikely, I know) there is one area where disabling bloatware can help a little.
Here lies my question.
Bloatware is also subject to updates, are these updates stored in the system partition? I doubt it, since it would be difficult for Samsung and the carrier to anticipate long-term storage requirements for their system partition. Therefore I am assuming that updates to bloatware would be stored in the "data/app" partition. If that is the case, uninstalling the updates to bloatware and disabling auto update in Google play store for that particular bloatware, will actually help in increasing/saving storage space?
