Tecno j7 battery
Not unless it is a removable battery and there is a physically larger one available with a larger back cover to accommodate it. Any direct-replacement batteries that are the same size as the original and claim a higher capacity are going to be fakes, the capacity is determined by the battery chemistry (Li-Ion) and its size. Sure it's easy for some manufacturer in China to stamp a different number on the battery and sell it as an "upgraded high capacity battery" but that's all it is, a label.
An alternative, if your existing battery doesn't last as long as you'd like and it isn't just worn out, is to use an external battery pack to keep the internal one charged longer. The external accessory batteries are plentiful and cheap these days and work with any device with a charging port.
