Tethering is possible on all Android phones. Even if the device does not support it out of the box, there are third party applications on Google Play for this.
Yeah USB can be a pain, especially when you forget where you put your USB cable, but it uses less battery than Wi-Fi HotSpot. in fact USB Tethering charges the battery.
Then Wi-Fi is essential. I'll check Google play for you to see if there are any Apps to suit your needs.
As far as the recovery for this phone ive build one recovery ad booted it onto my extra zte max but it bricked the phone so im back to square one. Ive got to figure out where the mistake is So im going to also look into seeing if tere was a recovery made for the 1st zte n9520 whic is the boost warp 4g lte. The two phones might have similarities. As soon as i get it working i will be posting it"
PhilZ Recovery was already made for the ZTE Max
http://androidforums.com/iconic-pha...recovery-philz-touch-6-19-2-need-testers.html
