Text notification - GoSMS Pro
thaKing
When the screen is locked and I miss a text, a little envelope appears on the screen. I can swipe it to open and view the message. Anyway to get it to open GoSMS instead of the default Messaging app?
I get that envelope as well. But I think its only when I get a MMS. When I just get text, while using Go SMS Pro, that envelope does not come up.
GoSMS should've auto picked that up. Try re-installing GoSMS pro and it should sort it self out.
OK, I did this, now to see what happens. After I re-installed I got to thinking - I *never* see that envelope. I mean, it's been a while, so this was random. So, I had my wife send a text and send an MMS to see what happens. Neither time did an envelope show up. I'm ok if it doesn't show up, but if it does, I want to make sure it goes to Go SMS Pro.
That's what I was thinking too. But I cannot get it to show now. Wonder if there is a setting somewhere that got reset once I re-installed it???
I thought this was just me
From time to time I get the same. But I never had uninstalled or re-installed and it just shows up from time to time then goes away on its own
