Help >>texting issues<<
its44379
Hey forum members,
I just got my Exhibit 2 4G, and already noticed a problem with texting. While on WIFI everything works fine. When WIFI off and 4g data pack ON, I can't recieve or send any text. When WIFI & 4g OFF, the voice texting feature won't connect and is unusable, but I can at least recieve and sent text the conventional way.
Any body experiencing the same or similar issues?
Any solutions?
thank you for your time members,
Glenn
Well first I will answer the voice texting feature. With all the data turned off on the phone voice to text will not work. Voice to text is designed to work with data service, speech recognition its not installed on our phones. It is installed on a server else where.
And if your using voice to text when you switch to only the 4G you may not be running the true 4G speed. If that's the case I have noticed that voice to text may time out and not work.
