Texting Problem
My granddaughter has a Samsung Galaxy SII (ST)......she's had it since Sept. '12.....2 days ago she began having text problems...she can RECEIVE texts OK...but cannot SEND them....she keeps getting a "Message Failed" after hitting "SEND"....
She has no trouble sending and receiving texts from Tango...
I've had her do the "soft" reset (power down, remove/replace battery, power up) to no avail.....I don't want to have to do a factory reset unless it's absolutely necessary!!
If it's a possible issue with APN settings...what should she/I be looking for?
ANY HELP is appreciated!
TIA!:)
TIA!:)
this happen to me too after three days like this i finally called straight talk my issue was in messaging app setting under (text sms messages)there is a number there that straight talk uses just make sure you dont mess with it.after i talked to then they changed that number to something else and after that every thing worked fine..
