Apps TextView.setText() problem.
m0rph3s
Code:
public void Generate(View view) {
  TextView temptextview = (TextView)findViewById(R.id.txtOutputMain);
  //txtOutputMain is the main Textview where I want to display results
  TextView tempsets = (TextView)findViewById(R.id.edtSets);
  ///edtSets is where you enter the number of sets
  String tempstr = tempsets.getText().toString();
  //This reads whatever I type into a tempstr
  int MySets = (int)Math.round(.33 * Integer.valueOf(tempstr));
  //33% of the total set - take the integer value.
  ArrayList<Integer> WhichSet = new ArrayList<Integer>(MySets+1);
  ArrayList<String> WhichName = new ArrayList<String>(MySets+1);
  //First array holds the set number that will be changed
  //WhichName assigns an exercise type
  Random rand = new Random();
  int dummy_var = (rand.nextInt(Integer.valueOf(tempstr))) + 1;
  //Randomize the total # of sets (tempstr) - this will give which set will change
  StringBuilder Final_View = new StringBuilder();
  //Make a string to hold set number/name information - I tried using String
  for(int i=1; i==MySets; i++) {
  //This will go from 1 to 33% of the sets (MySets)
  while (WhichSet.indexOf(dummy_var) != -1) {
  //indexOf should return -1 if the object isn't found - if it is found let's randomize
  //randomize because we found the same object somewhere in the string
  WhichSet.set(i, dummy_var);
  //Tried using .add(position, var) but no avail.  Still nothing here.
  WhichName.set(i, NumberToSetName((rand.nextInt(3)) + 1));
  //See above - calls my function which simply returns a str.
  Final_View.append(Integer.toString(i));
  Final_View.append(": ");
  Final_View.append(WhichName.get(i));
  Final_View.append(System.getProperty("line.separator"));
  //This was a last ditch attempt - tried using Final_View += and overloaded operators
  //Still doesn't display
  temptextview.setText(Final_View.toString());
  //I can't get this to display anything.  If I use a Var1="Blah" and set it as
  // temptextview.setText(Var1) it works perfectly.  Error must be in my set up but I can't
  //find it. Setting it to something like WhichName.get(1).toString() throws an error.
Comments describe what should be happening. Pretty new to this so maybe I'm missing something glaring. As it is I get nothing to display when Generate is run. I did try assigning a quoted string to a String value and passing it to the temptextview.setText and it worked. Really trying to be able to add my formatting though. Trying to pass the arraylist.get(#) results in an error though I'm not certain why. I do offset the arraylist count with a +1 to keep it on a 1:1 basis with the for loop so I don't have to deal with the initial 0 index. Any help would be greatly appreciated.
