Root tf101 bricked. easy flasher not working
jwbolfer
i have tried everything to fix it. it gets stuck on asus screen when booting after trying to restore to stock rom. i used the easyflasher method on windows xp. i cant get nvflash to load from cmd prompt either when clicking the exe. i have firewall disabled and running as admin. can someone please give me an idiot proof step by step guide to fixing this bricked tablet
If you hold volume down and power while it's turned off, wait 5 seconds, ten press volume up when it asks you to choose android, it should boot you into android.
1: power it off
2: hold volume down and power
3: IMMEDIATELY WHEN THE ASUS LOGO POPS UP, LET GO OF POWER. *NOT* VOLUME DOWN
4: wait 5 seconds
5: press volume up for android.
6: it should boot you into android now.
As for your easy flasher, I don't know. Instead, try using Pretty Easy Recovery Installer. (It works from adb)
http://forum.xda-developers.com/showthread.php?t=1681155
