Help The audio on my Zio is muddled when I use headphones
DRoyal23
So I've had this problem since I received the phone; the audio sounds clear without headphones, but when i plug them in, it sounds muddled. I know it's not the headphones I'm using; they work fine with everything else, and I even tried other headphones. Any suggestions?
Are you using the stock music player? I noticed I had the same problem when I'd plug the phone into my car's AUX jack. Once I downloaded a better music player (PowerAMP) the muffle went away. It seems to be a software problem, not so much a hardware one.
I had this issue and I thought maybe dust was blocking a contact. This has happened a few times and each time I just blow back into the headphone jack and it works. Maybe I'm lucky. But it can't hurt to try.
