The Battery
K3Nyy
I recently bought my G1 less than a month ago about a week into January. Today, my G1 suddenly died. I was using it before I showered and when I came back from my shower, it just died. I almost had a heart attack. The battery life wasn't near dead either. When I charged it, it didn't response, it didn't have the orange light where it usually had it. I tried turning it on too but that didn't work. Is there something wrong with my battery? I'm pretty sure it wouldn't die in less than a month. :confused: Help is appreciated.
I would think if you did not get the orange charging light, there is something else wrong besides the battery. I would suggest calling customer service at T Mobile.
make sure the contacts on the battery are touching sometimes if I sit on my g1 the wrong way it resets because (i think) the contacts separate for a second.
nope:)
Today, I took the battery out and put it back in. Then I turned it on, it worked fine. Then I went to bed and when I woke up today this morning, my phone didn't respond again. I tried charging it, turning it on with no luck. I never sat on my phone ever nor have I ever dropped it. Does anyone else have any suggestions?
well, you said it is less than a month old. I would exchange it, if your having problems this early in why chance it?
If you can't exchange it for some reason I would contact t-mobile, I've heard they will send you an extra battery for free.
Thanks for the suggestions. I'm going to contact T-mobile first and exchange if they can't fix it. Thanks guys. =)
