The K3 Note is compatible with 64GB SD card
lvt
Android Expert
When you are looking for the K5 Note you might see the description stating the storage capacity of 32GB max.
But in fact the K5 Note accepts any 64GB SD card, tested mine with two different 64GB cards and it works flawlessly in both portable and adoptive mode.
So if you like the K5 Note but didn't pull the trigger because you wanted more storage, think twice. It's a cheap and has the most powerful hardware in its price range.
